Activity Forums Adobe After Effects Expressions Total character in text
  • Total character in text
    Posted by Ilya Sire on January 25, 2017 at 1:58 pm
    Hi, i have a text wrote “JAPANESE” with text source use :
    c = thisComp.layer(“Null 1”).effect(“Slider”)(“Slider”); // to slide character
    text.sourceText.substr(0,c)
    another text to display character total. it count based on as slider change
    t=thisComp.layer(“JAPANESE”).text.sourceText.length //length doesn’t work
    how to get a total length of t?
    Ilya Sire replied 9 years, 8 months ago 2 Members · 4 Replies
  • Emre Anil
    January 25, 2017 at 3:11 pm
    Are you sure that “.length” is the problem?
    Your code seems perfectly working..
    Did you change the slider effect’s name to “Slider” or is it the default “Slider Control”?
  • Ilya Sire
    January 25, 2017 at 3:20 pm
    Yes the code is corrent, my goal to display a character count as slider animate count word “Japanese” to (number slider value / total char).
    it will be 0 to 8 / 8.
    but length wont take the total of text.
  • Emre Anil
    January 25, 2017 at 4:25 pm
    Now I get it.. you want to display as “current/total”
    For the actual text layer, use a text animator for opacity (set to 0) and change range units to “Index”
    Connect “Start” of range animator to your Slider with expression:
    thisComp.layer("Null 1").effect("Slider")("Slider")
    Add this expression to “End” of range animator to set it to the text’s length:
    For the counter text add the following expression to source text:
    t = thisComp.layer("JAPANESE").text.sourceText.length;
    i = Math.round(thisComp.layer("Null 1").effect("Slider")("Slider"));
    if(i>t){
    i=t;
    i + "/" + t;
    else if (i<0){
    i=0;
    i + "/" + t;
    else
    i + "/" + t
  • Ilya Sire
    January 25, 2017 at 5:06 pm
    That works beautifully, Emre Anil
    Thanks so much for your help!
