Activity › Forums › Apple Final Cut Pro › Total Adjustment – like Adjustment Layers for FCPX
  • Total Adjustment – like Adjustment Layers for FCPX
    Posted by Ben Holmes on February 21, 2012 at 2:46 pm
    Hi guys
    This has been around for a bit, but I just found it, in answer to a common query from a colleague new to FCPX (“where’s paste attributes?”) – Google led me here:
    https://rgbhouse.com/?p=74
    Effectively, it lets you create an ‘adjustment layer’ in FCPX, so CC, scale, distort etc. are all applied in the clips below it.
    Now – not the same as Paste Attributes, as you can’t then go in a tweak settings (you might as well use Paste Effects for this) but useful for lots of other occasions.
    I’ve never seen anything like this for an NLE – only AE offers this sort of effect layering, where it’s clearly of wider usefulness.
    Two things I like about this: 1. It’s free. 2. It shows how open and adaptable FCPX is becoming for developers. I see a Pro App economy building around FCPX already that reminds me of the iOS app store – ‘freemium’ business models, and plenty of economies of scale.
    Hope that’s of interest to some of you.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/community/communitydetails/?UserStoryId=8757
    Walter Soyka replied 14 years, 7 months ago 6 Members · 6 Replies
  • Andreas Kiel
    February 21, 2012 at 3:59 pm
    The procedure has been around since a few days after 10.0 release.
    It’s a simple title effect. Open Motion (which is recommend to buy if you don’t own it), create a new title and delete the text box. Publish and you’re done.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Ben Scott
    February 21, 2012 at 6:48 pm
    its the only way to apply a working broadcast safe filter as I am aware, be nice if there was something similar with audio
  • Simon Ubsdell
    February 21, 2012 at 6:52 pm
    [Ben Scott] “its the only way to apply a working broadcast safe filter as I am aware, be nice if there was something similar with audio”
    How about making all your audio into a single compund clip and adding a limiter to that? Or have you thought of that?
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
  • Jon Smitherton
    February 21, 2012 at 9:57 pm
    [Simon Ubsdell] “How about making all your audio into a single compund clip and adding a limiter to that? Or have you thought of that?”
    I’d rather have a roles mixer with inserts or master bus to do this like Pro Tools.
    Jon
  • Simon Ubsdell
    February 22, 2012 at 11:17 am
    [jon smitherton] ”
    I’d rather have a roles mixer with inserts or master bus to do this like Pro Tools.”
    Yes, but that’s not what you asked, is it? What I suggested would act in every meaningful sense like a master bus for the purposes of limiting your final mix.
    That said, in many parts of the world you’ll now need a lot more than that to produce “legal” audio as loudness metering has now become or is becoming a standard and you can’t do that yet inside FCPX.
    Although the great folks at NuGen have already produced suitable loudness metering plug-ins for FCP7 and Media Composer:
    https://www.nugenaudio.com/visLM_loudness-meter_VST_AU_RTAS.php
    Simon Ubsdell
  • Walter Soyka
    February 22, 2012 at 6:04 pm
    [Ben Holmes] “Effectively, it lets you create an ‘adjustment layer’ in FCPX, so CC, scale, distort etc. are all applied in the clips below it… I’ve never seen anything like this for an NLE – only AE offers this sort of effect layering, where it’s clearly of wider usefulness.”
    Just for completeness, Avid Media Composer can do this, too. Add filler on a track above your edit, and effects applied to the filler will work like effects applied to an adjustment layer.
    Walter Soyka
