TOSLINK to HD/SDI for 5.1?
Hi all. The subject pretty much covers it. I’m building a workflow in which I need to monitor 5.1 surround. We’re planning to purchase a TSL model console device that only receives a surround split through HD/SDI [BNC] inputs. Most of our sources for the audio will be consumer-grade devices [smart TV, tablets, Mac Mini, PC shuttle], and the most common output is optical [TOSLINK]. So the easiest thing to do would be to, somehow, convert optical audio to SDI.
But…can we? Will it work? Will we lose clock or sync? Will we lose fidelity? Will we maintain channel separation?
And if we can’t do this conversion directly, I know it’s possible to add a step and convert TOSLINK to HDMI, then the HDMI to the HD/SDI. But I’ll still ask the questions above, if someone can confirm that all the 5.1’s channels will remain intact. One of the points of using the TSL is its capacity to isolate individual tracks for testing. So if we can’t maintain the channel separation and assignments, no point in going on.
Ideas? Any ideas beyond? — thanks, Dave.
David J. Smolar
Preditor
inbetweenthings.com
