Activity › Forums › VEGAS Pro › Top Track Fades Get Applied to Bottom Tracks!!
  • Top Track Fades Get Applied to Bottom Tracks!!
    Posted by Ken Bennett on March 5, 2011 at 12:04 am
    I want to know if there is a fix for this problem.
    Two Tracks of video. Each track has been color corrected to match each other. Then I apply a fade-in or fade-out on the top Track shots, there is a sudden color change on the bottom Track at the first frame of the top Track as it starts to fade-in. The color correction (or any FX added) starts at 100% at frame 1 of the top Track changing the bottom Track. The applied FXs SHOULD fade-in with the top Tracks Event starting at 0% and ramping up to 100% at the end of the fade-in. NOT starting at 100% and effecting the bottom Tracks video.
    What is the work-a-round?
    THX
    Ken Bennett
    Video Adventures
    Capturing Your Life’s Adventures!
    Ken Bennett replied 15 years, 6 months ago 2 Members · 2 Replies
  • Graham Bernard
    March 5, 2011 at 6:18 am
    Without actually seeing a Screengrab of the Events, it does sound like you have an initial CC Fx Keyframe at 00:00 within the Event. Check and see if the CC is changing over time.
    Grazie
  • Ken Bennett
    March 5, 2011 at 9:48 pm
    Didn’t find any of that. I ended up in putting both camera on the same track and did a x-fade and then adjusted CC for each of the cam1 takes. Yes, its more work for me, but the end results look the way they should.
    Ken Bennett
    Video Adventures
