John Rofrano
August 30, 2011 at 8:50 pm[Keath Shelley] “it doesnt matter if i am using AAC?”
No, that’s what Vegas should be expecting. AVC/H.264 video with AAC audio.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Keath Shelley
August 30, 2011 at 10:27 pmYa that is what i am using but i dont get sound. And i am out of ideas.
John Rofrano
September 2, 2011 at 12:47 pmUnfortunately, I’m out of ideas too since this just works on my PC. Code-paks are usually the culprit in these cases but if you don’t have any installed then it can’t be. Still, another program could have installed a codec that interferes with Vegas. You might try re-installing Vegas as a last attempt to restore the functionality that you should have to begin with.
~jr
Stephen Lampett
October 11, 2011 at 6:48 pmHi, Ive have tried using the match function but im still having the same problem of only displaying the top left corner. I have imported as MP4 though. Are there any other suggestions you have?
thanks in advance
John Rofrano
October 11, 2011 at 10:43 pm[stephen lampett] “Hi, Ive have tried using the match function but im still having the same problem of only displaying the top left corner. I have imported as MP4 though. Are there any other suggestions you have?”
Don’t capture as MP4. Use the AVCHD setting which makes .TS files that edit fine in Vegas.
~jr
Stephen Lampett
October 12, 2011 at 6:06 pmthe problem with avchd is that the playback is jumping so i just get still image every 2/3 seconds. Also I get no sound.
John Rofrano
October 16, 2011 at 4:45 pm[stephen lampett] “the problem with avchd is that the playback is jumping so i just get still image every 2/3 seconds”
It sounds like you may need a more powerful computer. I have no problems playing AVCHD on my 2.66Ghz QuadCore.
[stephen lampett] ” Also I get no sound.”
That’s odd. The sound should be AVC which Vegas plays back just fine. It could be that some other software on your computer is causing a problem with Vegas. Programs like FFDShow can cause problems and code-paks are notorious for this so if you have any installed I would uninstall them and re-install Vegas. You might want to re-install Vegas anyway just to see if you get the audio back.
~jr
