Activity Forums Adobe After Effects toonification problems
  • toonification problems
    Posted by Zander on March 23, 2006 at 5:30 am
    ok, well ive been tunifying since cs2 got delivered to my door by fedex, for starters (and i know this part belongs in a different forum so sorry in advance) my a.e. podcast of part 2 (illustrator section) dies at exactly the moment befor Aharon says how to close the illustrator, i redonloaded it, same problem, checked my handy video ipod, and what do ya know, same problem, same spot. i switched over to the web version, but since im on a g4 laptop, it was veryfrustratoing having not enough ram for both illustrator and quicktime…grrr.
    ok but i got through it, im up to the importing, im excited to see my finished product (using my own footage) when i being to import, the first two folders (color and accents) come up with the message (26 frames are missing), so i open the third and final file of cartoon lines, with out a problem.
    so here im like, what ever if it works it works right? well thats the problem, not everything worked.
    when i began to interprate, the cartoon color (mind you this wasn’t a “full import” according to a.e.) it let me change my frame rate, gues my alpha all the goodies, but when i get to the lines (the one it said worked) it won’t let me adjust frame rate?
    im so confused
    help porfavor?
    thanks in advance
    -aaron
    Aaron Zander-Student edditor
    If it’s out there and it does somethign to something,
    teach me how to use it
    Powerbook g4 1.5 GHz (it might not be big, but i can take it on set
    fcp 5, ae 6.5pro adobe cs2
    Aharon Rabinowitz replied 20 years, 6 months ago 3 Members · 2 Replies
  • Matt Babinec
    March 23, 2006 at 5:57 am
    did you maybe just import a single frame from the lines folder instead of a sequence of images? that could be why you cant change the framerate, i did this too. make sure image sequence is checked off in the import files dialoug box.
  • Aharon Rabinowitz
    March 23, 2006 at 10:41 pm
    that was my guess.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
