Activity › Forums › Maxon Cinema 4D › Toolbar Beginner question
Posted by Julia K on August 18, 2006 at 3:31 pmHOw do you create a new toolbar in Cinema4d?
Thank you
Samir Kharchi replied 20 years ago 2 Members · 3 Replies -
Samir Kharchi
August 18, 2006 at 3:42 pmRight click on any free space of an existing toolbar and choose “New Icon palette” or “New Group”. Both should serve your purposes. 🙂
Julia K
August 18, 2006 at 5:35 pmI got that far, I had problems adding the icons to the new icon/group, tried dragging them in, or double clicking… it didn’t work…
Help…
Thank you
Samir Kharchi
August 18, 2006 at 7:15 pmyou must first start the editing. Right click on any space in the interface again and select “Edit palettes”. Then the whole interface is in editing mode and you can drag the existing icons around and replace them. The appearing command manager displays all commands Cinema 4D has to offer. Simply drag them into the layout where you want them (in your case, into the empty toolbar). Closing the manager will also stop the editing mode.
Window->Layout->Command Manager that
