Activity › Forums › DaVinci Resolve › Tool to search for black frames?
Posted by Michael Neumann on March 24, 2014 at 2:13 pmHey there,
my Resolve outputs black frames from time to time into my exported DNxHD files. Is there a way, a plugin maybe, that I can have premiere run through the file and alert me if there is a black frame?
Any help appreciated!
Jon Chappell replied 12 years, 5 months ago 3 Members · 4 Replies -
Eric Johnson
March 24, 2014 at 5:19 pmNot sure if it works with DNxHD, but I’, pretty sure Digital Rebellion has an app in one of it’s bundles that does something to that effect.
eric b johnson
online editor | colorist | workflow
https://vimeo.com/ebjohnson/colorreelSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jon Chappell
March 24, 2014 at 7:00 pmYes, it’s called Video Check and it’s in Pro Media Tools:
https://www.digitalrebellion.com/promediaBut it uses AV Foundation so no third-party codecs I’m afraid.
My software:
Pro Maintenance Tools – Tools to keep Final Cut Studio, Final Cut Pro X, Avid Media Composer and Adobe Premiere Pro running smoothly and fix problems when they arise
Pro Media Tools – Edit QuickTime chapters and metdata, detect gamma shifts, edit markers, watch renders and more
More tools… -
Michael Neumann
March 24, 2014 at 9:41 pmI tried “Video Check” and it worked well with an .mp4 and detected a flashing frame. The same file converted to DNxHD 4:4:4 (my main format) didn’t show up with any negative results although I could clearly see the flashing frame when scrubbing through the footage.
Also I would like the program to check about 500 files for export failures, which Video Check is not capable of (no batch).
Any other ideas?
I thought about running all the files through scene detection, which should work nicely but is also a lot of work.
Jon Chappell
March 24, 2014 at 10:30 pmAs I mentioned, it doesn’t support DNxHD.
My software:
More tools…
