Tool to display/extract ARRI metadata from SDI signal
Posted by Salvador Garza on January 16, 2016 at 7:36 pmHi everyone!
Does anyone know of any tool that displays or extracts ARRI extended metadata from an Alexa HD-SDI signal?
Salvador Garza
https://www.salvadorgarza.comSalvador Garza replied 10 years, 7 months ago 2 Members · 4 Replies -
Gary Adcock
January 17, 2016 at 5:25 pm[Salvador Garza] “Does anyone know of any tool that displays or extracts ARRI extended metadata from an Alexa HD-SDI signal?”
From a Live signal? That would require a rather expensive piece of test equipment.
If you just want to read the metadata after files are captured do a search for the Arri Alexa MetaData Extract tool.
gary adcock
Studio37Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, ILFollow my blog at https://www.garyadcock.com
Or follow me on Twitter
@garyadcock -
Salvador Garza
January 17, 2016 at 5:33 pmThanks Gary!
Yes from a live feed. So far my search has led me to QTakeHD, video assist software. It appears to be the only thing out there that does this, and yes quite expensive (for our intended application which is more along the lines of shot logging/reporting).
Transvideo appears to have a monitor that can do this, but not quite what we’re looking for.
Best,
Salvador Garza
https://www.salvadorgarza.com -
Gary Adcock
January 17, 2016 at 6:29 pm[Salvador Garza] “So far my search has led me to QTakeHD,”
There is also a variety of test hardware that also provides this function.
There are a few apps for script supervisors that can modify / read the data stream but those tend to be closed hardware systems that require a good deal on hands-on input to maintain the data continuity.Since Alexa’s are not widely used as LIVE production cameras, but more for episodic and cinematic workflows they do not have to tool set used in live production.
If you are doing what I think you might be, you should be looking into interconnected smart slates in conjunction with software used by script supervisors to maintain scene and take info independent of the camera system.
gary adcock
@garyadcock -
Salvador Garza
January 19, 2016 at 3:46 pmThanks Gary. LockIt Networks and Ambient Recording offer an interesting solution, like you said more for script supervisors.
Salvador Garza
