Activity › Forums › Maxon Cinema 4D › Too much render space (1min>75Gb)
Posted by Jose vladimir Reyes cordero on July 15, 2014 at 3:41 pmOk… I’ve a very simple scene, a minute long. Is it normal that take so much space (75 Gb)?
Or is there something I’m doing wrong?
Can somebody help me with this please?Jose vladimir Reyes cordero replied 12 years, 1 month ago 3 Members · 4 Replies -
Adam Trachtenberg
July 15, 2014 at 4:05 pmIt doesn’t seem out of line given that you’re outputting multiple passes of uncompressed 720p footage at 16 bits.
July 15, 2014 at 5:45 pmThank you…
And what settings should I adjust? because I’ve limited time and disk space…
I’m new to this 3D… This is my first professional render… please help… 🙁 -
Michael Szalapski
July 15, 2014 at 6:01 pmRender 8-bit.
Render fewer passes.Or, best idea: Get an external hard drive to render your image passes to. They’re relatively cheap and you will need the disk space if you plan to do any more of this. You will be using a compositing program like AE, to create a composite, rendering out of that and using a compression program (such as the Adobe Media Encoder) to make your final deliverable, yes? You’ll need the space.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
