Activity Forums VEGAS Pro Too much bass and rumble in audio playback
  • Too much bass and rumble in audio playback
    Posted by Brooks Kohler on June 30, 2008 at 11:47 am
    When watched through a system with Surround Sound I get a lot of bass and rumble. Is there a way in the audio settings to address this problem before I render?
    John Rofrano replied 18 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    July 2, 2008 at 5:23 pm
    Place an EQ on the main audio bus and cut some of the lower frequencies. If this is a 5.1 surround project and the low rumble is just coming from the LFE, cut some of the signal going to the LFE or EQ some of the bottom out on the LFE track.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
