Activity Forums Apple Final Cut Pro Legacy Tone audio overmodulated in Edit to tape mode
  • Tone audio overmodulated in Edit to tape mode
    Posted by Gene Bauer on June 9, 2009 at 5:42 pm
    When I go into Edit to Tape mode to lay off bars and tone the audio sounds way overmodulated. It sounds perfect in preview so it is not a Mackie board setting. It can’t be a feedback issue because I have black routed on the input. I could not find any settings in Edit to Tape module that would cause this. Any info would be greatly appreciated..THX
    Running 10.5.6 with FCP 6.0.5 on a MAC Pro 3,1 with 8GB and a Lacie RAID mounted via ESATA.
    Baz Leffler replied 17 years, 3 months ago 4 Members · 4 Replies
  • John Fishback
    June 9, 2009 at 9:08 pm
    Perhaps you are hearing both the FCP output and the playback from your deck at the same time. That could over drive the audio channel.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Baz Leffler
    June 10, 2009 at 1:42 am
    When I use FCP bars and tone for export to Digibeta and HDCam via my Decklink boxes I set the tone level to -20 which shows up correctly on the decks expanded level meters.
    Remember FCP tone is 0db and digital requires -20 (debatable but I stand by those specs cos thats whats in my deliverables contracts!)
    Baz
    What would I do without the ‘UNDO’ button!!!!
  • Michael Gissing
    June 10, 2009 at 3:50 am
    [Baz Leffler] “Remember FCP tone is 0db and digital requires -20”
    FCP actually defaults to tone @ -12dbfs. -20dbfs is correct SMPTE broadcast spec and -18dbfs is PAL broadcast spec. Australia is the only PAL country to adopt the -20dbfs SMPTE spec.
    Don’t sweat it though Baz, no-one seems to reject PAL tapes with -20dbfs tone anyway. At the end of the day, the tone reference on a digital tape is redundant but comforting to the old analog broadcasters.
  • Baz Leffler
    June 10, 2009 at 4:13 am
    [Michael Gissing] “Don’t sweat it though Baz, no-one seems to reject PAL tapes with -20dbfs tone anyway.”
    Yes I agree Michael – in fact I got a QC report from OS recently stating…
    “-20dBFS tone is incorrect for a tape of this standard”
    I thought to myself, “what does that mean? Is the tape quality to high for a meager -20?”
    Never the less, it didn’t get rejected, just a ‘mention’.
    So all future HD masters I sent had -20 mentioned on the label.
    [Michael Gissing] “At the end of the day, the tone reference on a digital tape is redundant but comforting to the old analog broadcasters.”
    YUP! But WHATEVER YOU DO…. don’t let program content exceed -10dBFS!!!
    Incidently most prosumer camera’s including the Sony Z1 tend to record audio 12dB too high and I am forever setting the master FCP faders to -12.
    Baz
