Activity › Forums › Apple Final Cut Pro › toMotion: Install Templates, Create Categories, Create Incremental Backups
  • toMotion: Install Templates, Create Categories, Create Incremental Backups
    Posted by Paul Figgiani on February 14, 2012 at 1:42 pm
    I wrote most of this code 6+ months ago. I’m just getting around to making it publicly available.
    toMotion, requires OSX ver.10.7 or higher.
    Use this application to move downloaded Motion 5 Templates (Effects, Generators, etc.) to the proper designated folder in ~/Movies/Motion Templates. You can also create custom “Categories” below the root Motion Templates folders for proper hierarchical storage/view in the associated FCPX Browsers.
    I’ve also included a backup utility. Set the path to the backup folder and you’re all set.
    Drag Template folders into the main UI or add via the File/Open action. **Please note the application *moves* Template folders from their original location.
    You can inspect the contents of your Motion Templates Folders using the “Reveal Motion Templates folder” action located in the application menu.
    I’ve included a link in the Help menu that explains the basic functionality of the application. Standard Disclaimer: Use at your own risk. I’ve used this tool extensively and have not encountered any issues.
    https://www.producenewmedia.com/toMotion.html
    -paul.
    Paul Figgiani replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
