Activity Forums Maxon Cinema 4D Tokens not working on r20
  • Tokens not working on r20
    Posted by David Cabestany on May 28, 2021 at 4:37 pm
    I’m trying to manually add some tokens to my naming convention but the rendered file is not creating the name I want, for example, I wrote this:
    C4D RENDERS/$MM_$DD_$YY/std_gi_NOao/$prj_$rs_$res_$take
    But instead of creating a folder with today’s date as the name (05_28_21) it just created a folder named $MM_$DD_$YY, the file name within the folder is right and using the tokens the way it’s supposed to.
    The date tokens are not included with C4D and are actually part of the CV Tokens plugin, which I do not own and can’t install because it needs r21 or newer to work, I thought that by just writing them manually they would work, is that not the case?
    David Cabestany replied 5 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
