Activity Forums Adobe Premiere Pro Toggling between sequences in Premiere Pro 2017
  • Toggling between sequences in Premiere Pro 2017
    Posted by Dale Holman wallace on March 30, 2017 at 1:56 pm
    Hi all,
    To toggle between sequences, I used to use the SHIFT + 3 command. In the latest update of Premiere Pro, this no longer works!
    Does anyone know what the correct command is to toggle between sequences. Or even better, does anyone know what the official name is for toggling between sequences so that I can search for it in Keyboard Shortcuts and set my own hot-key?
    Dylan
    Dale Holman wallace replied 9 years, 5 months ago 2 Members · 2 Replies
  • Jim Townley
    March 30, 2017 at 10:28 pm
    Are you using Version 2017.0.2 Release. I know the latest update took care of a lot of the shortcut problems that I had.
    I use Shift+3 to access the Timeline when I am in another panel. Once in the timeline panel, Shift+3 will switch from sequence to sequence. It is working for me.
    Regards
    Jim Townley
    Television Production
    Chattahoochee Technical College
    Marietta, GA
  • Dale Holman wallace
    April 1, 2017 at 10:12 am
    Yep, I do! I try to use the keyboard wherever possible. Toggling using the keyboard will save you about 20 minutes over the course of a long editing day, rather than reaching for the mouse each time, especially when you’re working with multiple selects sequences.
