Activity Forums Avid Media Composer toggle waveform in Media Composer
  • toggle waveform in Media Composer
    Posted by Justin Gray on November 8, 2007 at 3:33 pm
    OK, so I can toggle my waveforms, (sample plot) with the click of a mapped key on my keyboard in Express Pro. However, when exploring my command pallette in Media Composer 2.7 there is no toggle waveform button available to choose from. Isn’t there another way to turn my sample plot on and off rather than using the “fast menu,” of which is not fast at all, in the timeline? Thanks bovines. -J
    Carl Amoscato replied 18 years, 10 months ago 3 Members · 4 Replies
  • Jon Zanone
    November 9, 2007 at 12:13 pm
    I use the timeline view. At the bottom of the timeline, to the right of the step in/step out buttons, is a pull down menu. My bet is its called untitled. Pull down that menu, you’ll see ‘Save as…’. You can have multiple views stored here. I’ve got a base setting, then settings for audio work.
    Its not as elegant as a button, but I’ve got my keyboard settings crammed with other stuff I use on a daily basis. It works well for me.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Carl Amoscato
    November 10, 2007 at 4:48 pm
    I don’t know if this will work or not, but try selecting Menu to Button Reassignment, and then select Sample Plot from the timeline fast menu and assign it to a keyboard key.
    good luck,
    Carl
  • Justin Gray
    November 27, 2007 at 3:56 pm
    CARL, THANKS SOOOOOOOOOOOOOOOOO MUCH. FINALLY, THANKS TO YOUR SUGGESTION, SUCCESS! THANKS A BUNCH.
    -JUSTIN
    (SHOUTING INTENTIONAL)
  • Carl Amoscato
    November 27, 2007 at 6:26 pm
    JUSTIN, YOU’RE WELCOME!!! I’M GLAD IT WORKED!!! 🙂
    GOOD LUCK,
    CARL
