Activity Forums Adobe After Effects Expressions Toggle transparency
  • Toggle transparency
    Posted by Jace Bradley on April 6, 2022 at 12:59 pm
    Hello! I am new member 🙂
    I already have a question.
    I created a simple UI window with a button to toggle on off transparency.
    I ‘m just learning. When I search the Scripting guide I see;
    app.project.transparencyGridThumbnailsapp.project.transparencyGridThumbnails
    First, what’s Boolean; read/write. I thought Boolean was true and false or is read/right the same thing?
    How can I tell the function to turn the transparecy on and off?
    Thank you.
    Sean Walkup replied 4 years, 5 months ago 3 Members · 2 Replies
  • Tomas Bumbulevičius
    April 9, 2022 at 5:20 pm
    Hey Jace. What object transparency we are talking about? Where and what you want to toggle on/of? Is it a layer in the composition? If so, do you select that manually, or how it will be decided what to turn on/off?
    Or are you talking about transparency in they GUI?
  • Sean Walkup
    April 12, 2022 at 1:38 pm
    Not sure I completely understand your need, but maybe this will help.
    Here is how to turn another layer on and off with a checkbox expression control. I use this all the time to control dozens of things in mogrts for Premier.
    In this example, I have an empty shape layer named Controllers that contains a checkbox. I have another shape layer called Square, and in its opacity, I have this:
    var cbx=thisComp.layer(“Controllers”).effect(“Checkbox Control”)(“Checkbox”);
    if(cbx>0) {100} else {0}
    Hope this helps.
