Activity › Forums › Adobe Premiere Pro › Toggle source/record in the timeline like Avid?
Posted by Chris Conlee on May 6, 2016 at 8:09 pmIn Avid Media Composer I can easily swap the source monitor’s contents to the timeline, and then back. This is useful when editing one sequence into another, as you can see your edit points, and you can easily jump from cut to cut in your source sequence. Can you do the same thing in Premiere somehow? To clarify, you’re able to simply view the source sequence as a timeline, it doesn’t actually move anything to the existing timeline. It’s just a button-push to toggle between a sequence view of the source monitor, and the sequence your cutting in the record monitor.
Chris
Alex Udell replied 10 years, 4 months ago 3 Members · 9 Replies -
Chris Conlee
May 6, 2016 at 8:27 pm -
Chris Conlee
May 6, 2016 at 8:36 pmGuys,
For some reason I thought this copy / paste wasn’t working before, but it is now, so I think problem solved. Thanks.
C
Matt Galuszewski
May 6, 2016 at 9:49 pmIf you are wanting to edit content from one sequence to another you can also open a sequence in the source monitor, select in and out points, patch and edit.
https://helpx.adobe.com/premiere-pro/using/edit-sequences-loaded-source-monitor.html
Is this what you originally wanted?
Chris Conlee
May 6, 2016 at 10:01 pmI know you can put a sequence in the source side and edit with it, but I wanted to be able to see the source side sequence while making my in/out selects like I’very gotten used to doing in Media Composer. Copy/paste is probably the closest I’ll get.
Alex Udell
May 16, 2016 at 5:59 pmWith a sequence loaded into the source monitor…
click on the wrench icon in the source viewer….
choose “open sequence in timeline”
this will open a sequence tab with the name of the sequence followed by (source monitor)
this is what you are looking for…
Alex Udell
Editing, Motion Graphics, and Visual FX
Let’s Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial -
Chris Conlee
May 16, 2016 at 8:40 pmAlex, that is almost exactly it! But what I would really like is the same functionality for “merged” clips, so I can see the waveforms on all 8 tracks of my synced audio. This makes it so much easier to know which tracks have active sound when making edit decisions. I wasn’t able to test extensively, but it seemed like I wasn’t able to get merged clips to open on the timeline. Am I wrong? Or is there perhaps a work-around?
So close!
Chris
Alex Udell
May 17, 2016 at 2:07 amHmmmm…..
only thing I can think of is using a sequence in place of “merged clips”
where the sequence is alignment of the audio and video…
don’t forget too that when you edit from a sequence to a sequence you can edit as a nested container or tracks to tracks…
Alex Udell
Chris Conlee
May 17, 2016 at 2:38 amYeah, if I’d set the project up myself, that’s probably what I would have done; made synced sequences. Although somebody would have to explain to me the benefit of using nested containers, as that’s not a workflow that’s available in Avid, and I’ve never done it. But alas, I didn’t set up the project, so I’m slogging thru best that I can. It’s sometimes frustrating, but I’m getting it done.
Chris
Alex Udell
May 17, 2016 at 2:39 pmbefore we had adjustment layers, nests were the only way to apply a single effect to a group…
classic example would be…
4way split that you want to fly in and out….
nest gives you one axis….
but it’s non destructive because you can step in and edit/replace sources within…
Alex Udell
