Activity Forums Adobe Premiere Pro Toggle proxies
  • Toggle proxies
    Posted by Vasco Daneva on November 17, 2017 at 3:43 pm
    I finished a 4K project using proxies and encoded it. Only after I erased everything did I realize that before encoding I had forgotten to toggle the proxies icon back to 4K. In other words the icon was still blue when I sent it to Encoder. My question is What did I make? A proper 4K clip or a 4K clip from 720p proxies (and therefore a fool of myself)?
    Vasco
    Vasco Daneva replied 8 years, 10 months ago 3 Members · 6 Replies
  • Tero Ahlfors
    November 17, 2017 at 5:34 pm
    Exports shouldn’t use proxies.
  • Vasco Daneva
    November 18, 2017 at 11:44 am
    I thought so too but on one tutorial a guy said you should turn off the Toggle proxies icon. I didn’t, hence my question.
  • Tero Ahlfors
    November 18, 2017 at 12:20 pm
  • Peter Northall
    November 18, 2017 at 12:42 pm
    The toggle proxies button makes no difference to exporting. Full res is always used (as long as it’s online).
  • Vasco Daneva
    November 18, 2017 at 12:49 pm
    You mean where it says: • When you render Previews, Export Media or use certain Analysis effects (Warp Stabilizer, Rolling Shutter Repair, Morph Cut), Premiere Pro always uses and displays Full Res, regardless of the Toggle/Enable Proxies setting. The only exception is when you have Offline Full Res, but Proxy is Online, then Proxy is used.
    I read it but like I wrote earlier… there was this tutorial… Anyway, my question was answered. Thank you.
  • Vasco Daneva
    November 18, 2017 at 12:50 pm
    Thank you very much! What a relief.
