Activity › Forums › Adobe After Effects › Toggle Pixel Aspect Ratio Correction?
  • Toggle Pixel Aspect Ratio Correction?
    Posted by Grirk Plongmak on February 3, 2014 at 4:26 am
    This question maybe stupid but I really need to know. TV commercial in Thailand are in Pal 25fps. So when I work in AE I alway use D1/DV PAL (1.09). My question is when I press Toggle Pixel Aspect Ratio Correction is this view the correct one? i.e. circle are circle not squashed ellipse shape to the eye and square are perfectly square to the eye. I’ve seen many commercials and some look correct when the toggle is on and some look correct when the toggle is off. What is the correct one? Thanks
    Roland R. kahlenberg replied 12 years, 7 months ago 2 Members · 5 Replies
  • Roland R. kahlenberg
    February 3, 2014 at 12:18 pm
    Sawadeekarp! In AE, you should always work in square pixel aspect ratio (PAR) comps. Then, if required to output to a non-square PAR, you nest your ‘final’ composition into a non-square composition and render.
    There is a very good article from Rick Gerard here – https://library.creativecow.net/articles/gerard_rick/pixel_madness.php
    HTH
    RoRK
    Latest AE Workshop –
    https://www.broadcastgems.com/mographintensity_shapestext/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Grirk Plongmak
    February 3, 2014 at 2:25 pm
    Kopkoonkrub! Thanks for the answer. So if I work with Pal Square pixel then the images or the footage I see should be correct. Circle will appear to be Circle. Is this correct? if it is correct then I assume that when I click the Toggle Pixel Aspect Ratio Correction in an D1/DV PAL (1.09) comp and the comp stretches out on the side is the correct view (Circle will appear to be Circle). If I get anything wrong please tell me. I will get to read the article. Thanks again.
    February 3, 2014 at 3:34 pm
    You are right! As long as you work in square PAR, you don’t need to check, using PAR correction. Well, perhaps only at the final step when you nest into a non-square PAR.
    On a related matter, ensure that any graphics that you create in PS or AI are also in square PAR.
    Cheers
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
  • Grirk Plongmak
    February 3, 2014 at 4:28 pm
    Thank You very much RoRK!!! Now I can work with more confidence. You have been a great help.
    Cheers!
    February 3, 2014 at 10:06 pm
    You are most welcome. Having confidence in yourself and the software is integral to creating good stuff.
    Cheers
    RoRK
