Activity › Forums › Apple Final Cut Pro › toggle multiple clips
Posted by Jason Brown on July 18, 2012 at 2:38 amI’m adding favorites to clips, and I want to select multiple clips and toggle the arrow next to the clip to hide. Is there a way to do this to multiple clips?
Anyway to disable the clip expanding to show the favorite when I add it? Can I just add and move on?
Joni Church replied 12 years ago 5 Members · 7 Replies -
Andy Neil
July 18, 2012 at 4:07 amTo answer your first question: yes. Select all the clips in your event browser and hit OPT+left arrow to close the disclosure triangle and hide favorites and keywords. OPT+right arrow will expand to show them.
For your second question, you can’t stop it from showing the favorite when you create a favorite, but it shouldn’t stop you from quickly going through your clips. The clip you are on will remain active after a favorite has been completed, and if you want to jump down to the next clip in the browser, you only need hit the down arrow key.
Andy
https://www.timesavertutorials.com
Jason Brown
July 18, 2012 at 2:03 pmThanks Andy for the response…this is cleaning up my workflow quite a bit.
[Andy Neil] “Select all the clips in your event browser and hit OPT+left arrow”
Just tested this and actually, there’s no need to press option…just the left and right arrows collapse and expand.
Thanks! 🙂
Jonathan White
July 18, 2012 at 2:31 pmThanks for the tip, very helpful as the disclosure triangles close up every time I change keyword folder or event…. used to have to open them all individually every time!!
JohnnySeanchas Productions, Galway, Ireland
Kyle Bass
July 18, 2012 at 5:12 pmNice. I was also getting a little annoyed with those disclosure triangles. This will speed my organizational tasks up a bit.
Joni Church
August 26, 2014 at 5:43 pmHi Jason and Andy,
I see that this is a very old post, so I’m wondering if the current version of FCPX has changed.
It sounds like when Jason added a Favorite to a clip, the clip automatically expanded in the browser to show the Favorite. Andy mentioned there was no way to stop it from doing that.
I’m having the opposite issue, actually. I *want* the clip to expand automatically when I add a Favorite so I can then name the Favorite without having to manually toggle the arrow open, but when I add a Favorite, the clip doesn’t expand.
Did this change in one of the FCPX updates maybe? Or is there a way to force the clips to automatically expand?
Thanks a lot for any thoughts,
Joni -
Jason Brown
August 27, 2014 at 4:49 amLooks like it has changed. What I was trying to do before is what I can do today in 10.1.3.
Joni Church
August 28, 2014 at 6:36 pmAh, I figured as much. But I had to hold out hope that there might a way to choose! Sometimes it’s the littlest things…
Thanks for the confirmation, Jason.
