Activity Forums Adobe After Effects Expressions Toggle layer’s Opacity On/Off using a Checkbox
  • Toggle layer’s Opacity On/Off using a Checkbox
    Posted by Mervin James on January 21, 2019 at 7:30 pm
    So Im trying to turn a layer on and off using this well known expression, in After Effects 2019 and for the hell of it I dont know why it isnt working. It works fine in After Effects 2015 and 2018. So im thinking 2019 has a problem or something. Here is a screenshot below. Any help if appreciated.
    I have also tried using the expresson below also with no luck:
    thisComp.layer("Adjustment Layer 1").effect("Checkbox Control")("Checkbox") ==1)100 else 0;
    Mervin James replied 7 years, 7 months ago 3 Members · 3 Replies
  • Dan Ebberts
    January 21, 2019 at 7:39 pm
    The new JavaScript expression engine is more strict about the syntax for single-line if/else statements. This should work:
    thisComp.layer(“Adjustment Layer 1”).effect(“Checkbox Control”)(“Checkbox”) == 0){0}else{100};
    Dan
  • Alex Printz
    January 21, 2019 at 7:47 pm
    could do it like a ternary operator as well:
    thisComp.layer("Adjustment Layer 1").effect("Checkbox Control")("Checkbox") == 1 ? 100 : 0;
    Alex Printz
    Mograph Designer
  • Mervin James
    January 21, 2019 at 8:03 pm
    Very thankful for the responses Dan and Alex. Both work flawlessly.
