Activity Forums Adobe After Effects Toggle a layer’s opacity (or other property) on/off to preview effects?
  • Toggle a layer’s opacity (or other property) on/off to preview effects?
    Posted by Adrian Rössler on November 29, 2011 at 10:55 pm
    Hello, I did a search for this question, but didn’t see any promising results; my apologies if this is AE 101.
    When working on a project, I sometimes find myself wishing I could briefly toggle a 0% opacity layer visible, to work on its parameters/effects at that specific frame.
    What I end up doing is set the opacity to 100%, thereby creating keyframes which I later have to clean up again. Opening the layer itself in the viewer allows me to preview effects individually, but not the whole stack, and not in conjunction with the other layers.
    Adrian
    Adrian Rössler replied 14 years, 9 months ago 3 Members · 4 Replies
  • Jim Bunger
    November 29, 2011 at 11:00 pm
    You can use the eyeball to the left of the name to turn that individual layer on and off, if thats what you are asking. also you can “Solo” a layer by clicking the box to the right of the eyeball. On another note when doing effects in your effects control panel you can click the F/X to the left of the name and turn individual effects on and off.
    Hope this helps.
    Director/Producer
    Kearney Media
    Kearney, NE
    http://www.kearneymedia.net
    “Film in Nebraska, where the men are men and the sheep are pants” – NE Film Commision
  • Adrian Rössler
    November 29, 2011 at 11:15 pm
    I’m looking to do that, but with a layer whose opacity is 0% at that frame. I want to see it despite that and without messing with keyframes of that property. Unfortunately neither the ‘Eye’ nor ‘Solo’ can achieve that to my knowledge.
  • Ben G unguren
    November 30, 2011 at 6:41 am
    Not that you really want to do this, but you could do a relatively simple expression on the opacity. Just add a Checkbox Control effect to the layer, then give your opacity this expression:
    if (effect("Checkbox Control")("Checkbox")==1) {
    100;
    else {
    value;
    Now when the box is ticked, the opacity will be 100%; when it is unticked, it will return whatever value the keyframes dictate.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Adrian Rössler
    November 30, 2011 at 3:31 pm
    Alright, thanks for the tips. Too bad this isn’t realized natively in the GUI. The workarounds offer little advantage over creating/deleting keyframes; both things take up time and have to be cleaned up afterwards. I’ll keep doing it as usual, things could be far worse!
