Activity Forums Apple Final Cut Pro Legacy Toast VS Toast Pro?
  • Toast VS Toast Pro?
    Posted by Chad Graves on March 3, 2010 at 6:26 pm
    Which one is better, what do you recommend, which one have you used, and why did you buy the one you have versus the other one? I have a 17 inch MacBook Pro and Final Cut Pro Studio that I bought in November. I will also be using a Caldigit VR. If you need any more info, please let me know.
    Thank you,
    Chad
    Stephen Fox replied 16 years, 6 months ago 5 Members · 6 Replies
  • Warren Eig
    March 3, 2010 at 6:38 pm
  • Chad Graves
    March 3, 2010 at 7:02 pm
    What do you have? Are those third party apps worth the extra $60? What are those third party apps?
    I also read that Pro offers these things versus the Regular Version:
    • Blue Ray component – enables burning BR-disks on an ext. Blue-Ray burner
    (and even small eg 20min BR-material on standard DVDs (only play back on BR-player))
    • Sound Soap (very good program to save bad audio – in a small way)
    • FotoMagico – If You want HD SlideShows
    I have also read some of the info that Roxio has put up, but I want to hear what people’s experiences have been with both versions.
    Thank you,
    Chad
  • Michael Sacci
    Why not just go to the website and click the compare. Do you need things that are listed in the Pro only column, if yes buy that version.
    #1 reason for the Pro version is probably to burn BluRay disc.
    https://www.roxio.com/enu/products/toast/default.html?gclid=COzO7oqhnaACFZZg2godI3gWeg
  • Chad Graves
    March 3, 2010 at 7:15 pm
    Thank you Michael for your post. I want to hear what people’s experiences have been with both versions. I am glad that you provided that link, because I didn’t see it on there website, thank you.
  • Greg Barringer
    March 4, 2010 at 1:45 pm
    I bought the Pro version because I wanted the BD authoring. The menus for burning are very basic and do not look professional IMHO. It does work and for personal use it would be fine for Blu-ray. If you’re doing this professionally then I’d look at other options. The third party apps are OK but didn’t offer anything I don’t already have, I’m not using any of them. The maximum bit rate for the BD is 26Mbps.
    I came from Windows and Sony Vegas Pro. I installed BootCamp, Windows7 and Vegas Pro 8.0, I’m using DVD Architect for BD authoring which can give a professional menu with customized sub-chapters and personalized layout. The maximum bit rate for BD is 40 Mbps.
    If you’re not looking for BD authoring go with the standard version.
  • Stephen Fox
    March 6, 2010 at 5:33 pm
    If you don’t need the additional programs but would like to have the Blu-ray plug-in, you can purchase the plug for Toast 10 for $20.00.
