Activity Forums Apple Final Cut Pro Legacy To Up-res or not
  • To Up-res or not
    Posted by John Dehn on September 17, 2010 at 11:20 am
    A documentary film that I helped produce is going to be projected at a festival. The project was done in DVCPro-50. The festival will accept either Blu-Ray or a standard DVD. Do you think I will gain anything by up-resing my quicktime movie and delivering it in Blu-Ray? If so, I’ve heard the After Effects does a better job with the up-res than Final Cut.
    I appreciate you thoughts.
    Mark Spano replied 15 years, 12 months ago 3 Members · 2 Replies
  • Shane Ross
    September 17, 2010 at 11:22 am
    You will gain nothing. Your footage is SD, making it HD won’t make it any better. Make an SD DVD.
    Shane
  • Mark Spano
    September 17, 2010 at 10:07 pm
    Allow me to offer one slightly contrary argument:
    If you send an SD DVD, you have no control over how it will look if it going to be up-converted or played back in a Blu-Ray player at the destination. If you up-res and make a Blu-Ray, while you do not gain any benefit or resolution or image quality, you at least have more control over how it will eventually look when played.
    Just two bits…
