Activity › Forums › Boris FX Particle Illusion › To reset emitters to default?
Posted by Kurt Muller on September 23, 2009 at 7:23 amGuys, if you alter the properties of an emitter and add it to the library, how can you go back and reset it, if you don’t remember its original settings?
Kurt.Kurt Muller replied 16 years, 12 months ago 2 Members · 4 Replies -
Alan Lorence
September 23, 2009 at 8:08 pmThere is no way. The library emitters are the “default” state. If you’ve overwritten a library emitter, you’ll need to download the library again.
Alan.
Kurt Muller
September 24, 2009 at 1:08 amOkay, thanks, Alan.
I guess I’ll have to be careful not to save modified emitters by the original name.
Cheers,
Kurt.
Alan Lorence
September 24, 2009 at 11:56 amThe name doesn’t matter. You can have 20 emitters in the same library that have the same name.
If you added a library emitter to the stage, edited it on the stage, then used “add to library”, you’ll still have the original in that library too — unless you deleted it from the library.
Alan.
