Activity Forums Apple Final Cut Pro Legacy To RAID or not
  • Posted by Chuckfaz on January 28, 2007 at 5:02 pm
    What’s the advantage of any RAID drive over a non raid drive? I’m contemplating just getting the non raid G-tech mini so why should I spend the money for the RAID version?
    Best,
    Chuck
    Charles Fazio
    Managing Partner
    Mark Rivera’s NewYork State of Mind Entertainment Group (NYSOM-EG)
    Entertainment
    Gary Adcock replied 19 years, 8 months ago 3 Members · 2 Replies
  • Shane Ross
    January 28, 2007 at 8:18 pm
    Speed and additional RT with many codecs….if you add multiple layers. With a regular firewire drive you might get 2-3 layers of RT video if you edit DV. A Raid will get your more layers of RT.
    Plus you can work with larger formats like Uncompressed SD and HD.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Gary Adcock
    January 28, 2007 at 10:28 pm
    [chuckfaz] “What’s the advantage of any RAID drive over a non raid drive?”
    Chuck
    RAIDS ( Redundant Arrays of Independent Drives) allow for greater performance on capture- and when working in HD content I would not ever suggest someone capture to a single drive. Drives like the Graid Mini allow a user the highest bandwidth for capture and playback with the least amount of effort or Overhead.
    I was lucky enough to test some of the early versions of the mini and was very impressed. 10bt SD and DVCPROHD compressed content played back flawlessly.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
