Activity Forums Adobe Encore DVD To pal or ntsc that is the question?
  • To pal or ntsc that is the question?
    Posted by Roen Davis on September 22, 2006 at 5:17 am
    Hi there !
    we are down under PALies and we are sending a festival entry DVD to the US and not sure whether it should be PAL or NTSC – and since the master is PAL I am guessing that Encore will not “standards convert” – any advice will accepted with open arms!
    Neil Wilkes replied 19 years, 11 months ago 3 Members · 3 Replies
  • Neil Wilkes
    September 22, 2006 at 9:59 am
    95% of all PAL machines will play an NTSC disc.
    95% of all NTSC machines will NOT play a PAL disc.
    If you are sending to the USA, it must be NTSC. Simple.
    “Standards Conversion” of an authored disc is next to impossible to do.
    Menus are a different resolution & PAR.
    Video is a different resolution & frame rate.
    You must rebuild as an NTSC project – redesigning all menus, and converting all Video.
    Sorry about this – but that is the way it is.
  • Vince Becquiot
    September 27, 2006 at 3:27 am
    The best way to convert to NTSC using a software based solution is Canopus Procoder IMO.
    Vince
  • Neil Wilkes
    September 27, 2006 at 6:13 pm
    Which will not do the menus.
