Activity Forums VEGAS Pro To make an arrow move across a graph using track motion
  • To make an arrow move across a graph using track motion
    Posted by Joseph Dezordi on June 19, 2005 at 2:37 pm
    I need to make an arrow float across a graph, [which is a JPEG,] to point to different things in the graph, [the arrow is made in photoshop on a transparent back ground],
    I find the track motion & key framing confusing, I don know to how to use it
    Should I use the Track motion function on the or the Pan crop function
    [ In this case the arrows have to move from the left to the right]
    if using mutliple arrows in different positons, does each arrow have to have its own dedicates videotrack?
    Peter Wright replied 21 years, 2 months ago 3 Members · 3 Replies
  • Mary Waitrovich
    June 19, 2005 at 3:08 pm
    Definitely use Track Motion and put each arrow on its own track. With keyframing, it’s useful to think in terms of starting and ending positions. Set the beginning position of the arrow, then move to the point on the timeline where the motion stops and place the second keyframe. If you want the motion to be exactly linear (no acceleration), set the smoothness to 0.
    Hope this helps.
    Mary Waitrovich
    UW-Madison
  • Joseph Dezordi
    June 20, 2005 at 12:20 am
    Thank you for this advice
    Do you know where I can find a range of arrows/ other graphic design drawing objects….which have a transparent backgound that I can use in an alpha channel for the track motion??
  • Peter Wright
    June 20, 2005 at 3:56 am
    Try using Wingdings or simlar as a font in the Text Generator. This way you can resize using font size, rotate with Pan Crop or Track Motion, change position using either P/Crop, Track Motion or Placement in the Text generator, and add outline or shadow.
    To see which Key does which character, Windows has a Character Map accessory – under WINDOWS/System 32/charmap.exe. I keep a shortcut on the desktop.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
