Activity Forums Adobe After Effects To make a loop hold, at a specific frame
  • To make a loop hold, at a specific frame
    Posted by Alex Volkov on August 6, 2010 at 12:48 pm
    Hi
    I have succeeded making a loop on my comp (using loopOut() expression) but now I want to make it hold at a specific frame and stay there. A solution for this is obvious – to make another layer, which begins with a same (hold) keyframe, as where the loop last stopped.
    But..
    Is there an easier solution for this? Or is this the only one? Is it possible to make my looping layer to stop looping somehow?
    I tried adding a Hold Keyframe (on my looping layer) on a specific frame, but that only resulted in the animation only playing once, and not looping at all in the first place. Meaning – Hold Keyframe screwed up the entired loopOut() expression, unless I did something wrong.
    All help is appreciated.
    Michael Szalapski replied 16 years ago 3 Members · 3 Replies
  • Dave Johnson
    August 6, 2010 at 1:40 pm
    Nest your looping comp into a new comp (to avoid possibly messing up the expression) by dragging it onto the comp icon in the project panel (to make sure it has all the same comp settings) and apply time re-mapping to the layer in the new comp. Then, go to the last time-remp keyframe at the end of the layer (which is created automatically when you apply time-remapping), copy it and paste it a second further down in the timeline (or however long you want it to hold on that frame). Might sound complicated, but it’s very simple.
  • Michael Szalapski
    August 6, 2010 at 1:41 pm
    I believe you can do something like what you’re asking with some expression trickery. I think it was discussed within the past month on the expressions forum. I would search around over there.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Michael Szalapski
    Or what Dave said. 🙂
    – The Great Szalam
