Activity Forums Blackmagic Design To install only Blackmagic codec.
  • To install only Blackmagic codec.
    Posted by Alejandro Castan on January 10, 2011 at 5:06 pm
    Hello all
    Sorry but I would need to install only the Blackmagic Decklink Extreme HD for Windows into one PC without Adobe Premiere and Decklink Video Capture card, for it, Could anybody help me with this topic
    Thanks in advance
    Best Regards
    Alejandro Castan
    Joshua Helling replied 15 years, 7 months ago 3 Members · 3 Replies
  • Shane Ross
    January 10, 2011 at 8:07 pm
    You don’t need a capture card to install the drivers. But as far as I know, there are no “Decklink codecs.” Just settings for existing codecs for the various NLEs. Apple has ProRes, so Decklink installs drivers that allow the card to see those ProREs files. But it doesn’t install ProRes.
    What Decklink Codec are you talking about?
    Shane
  • Alejandro Castan
    January 12, 2011 at 7:09 pm
    Hello Shane,
    First, thanks for your answer.
    Well, I have a Decklink Extreme 2 HD Card.
    On the other hand, I fixed the problem because I installed all the Blackmagic software and I can work without the decklink card installed.
    Thanks for your help.
    Best Regards
    Alejandro
  • Joshua Helling
    January 13, 2011 at 7:22 pm
    Excellent, that’s correct. You can install our drivers without a card and that will allow working with the project settings and codecs.
    We used to have a separate codec pack, but we discontinued it. It is much simpler to maintain one installer package than two.
    Always make sure that you have the same version of the drivers installed on both the systems.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
