Activity › Forums › Adobe Premiere Pro › to import quicktime . mov , mpeg-2 linear PCM into premiere pro CS4
  • to import quicktime . mov , mpeg-2 linear PCM into premiere pro CS4
    Posted by Andres Pinilla on December 12, 2009 at 8:52 pm
    I´m having trouble to import .mov files that were captured by a friend on a MAC plataform (final cut) into my PC plataform machine I´m using Premiere CS4 and he´s using final cut to capture, but when I import the files It says that that´s an unrecognized codec format, so what we´ve been doing is , he´s generating an uncompressed .mov and I´m importing those files, the problem is taht those files are huge I mean, the clips that I´m capturing straight on my computer is like 5gb 1 hour and the files that he´s capturing and editing on his pc also are like the same size. but in order to use his material on my edition bay I have to generate this uncompressed quicktime that goes for likealmost 80GB one tape(1 hour) footage, does anyone know how I can solve this problem?
    Steve Liang replied 16 years, 7 months ago 3 Members · 3 Replies
  • Jon Barrie
    December 12, 2009 at 11:18 pm
    What kind tape is the video coming from? If it’s DV and not HDV your friend can capture QuickTime DV files and a PC running CS4 should be able to open it fine. If the files are HDV then you’re going to have to jump through some process hoops.
    Is ther a reason you can’t capture the tapes yoirself with PPro?
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Andres Pinilla
    December 12, 2009 at 11:41 pm
    no special reason but he had captured everything already so I don´t want to capture evrything again…
    I´m pretty sure he used HDV tapes
  • Steve Liang
    February 28, 2010 at 7:53 am
    I tried demux the mpeg2 out of .mov file using the method described here:
    https://forums.atomicmpc.com.au/index.php?showtopic=5483
    Only files around the size of 10M bytes would work. Most of my files are larger than 10M bytes:O(
