Activity Forums Compression Techniques to high bit-rate for h264
  • to high bit-rate for h264
    Posted by Accountneedsrealnameupdate on July 31, 2007 at 8:53 am
    Hello,
    I want to upload a clip for current tv. I know from uploading clips to youtube you want the largest file possible, due to the file being re-encoded. So I used the h264 codec at 2mps, and get a 6.7meg file for a original 623meg file which is uncompressed. I think that this is to small a file to be re-compressed by videoegg, so I up the bitrate until at 30mps I get a 45.8meg file. Will there be a problem with using a bitrate this high if it is going to be re-encoded anyway? Is there a point where increasing the bitrate will have no effect on the file?
    Richard Sanchez replied 19 years, 1 month ago 2 Members · 1 Reply
  • Richard Sanchez
    July 31, 2007 at 5:59 pm
    I’ve found with You Tube, that it’s not neccessarily that you want to have the largest filesize possible, but that you want to follow their specs of 320×240 and 29.97 fps. They do recompress their videos anyway, but as long as you stick to those specs and use a good mpeg 4 codec, like h.264, or I frequently use the Sorenson AVC codecs, you’ll get good results. Check out Current TV for a spec sheet, I’m sure they’ll have a set of specs to get optimum results. Every server will be different and have different bandwidth requirements.
    To answer about is there a point to where bitrate won’t affect the video quality, yes there usually is a point to where higher bitrate doesn’t neccessarily result in any cleaner video, but that point will depend on the codec. I find with h.264 at 320×240 there’s rarely a need to go much higher than 768 kbs. Sometimes with very high motion video I’ll go up to 1200 kbs, I always spit out my first encode at 768 to get a good frame of reference.
