Activity Forums Apple Final Cut Pro Legacy To export still frame from HDV
  • To export still frame from HDV
    Posted by Renata on June 21, 2007 at 3:14 am
    Hello!
    I’m writting again because I didn’t see my post in the forum, so I’trying it one more time!
    I’ve captured HDV native and it looks alright in Final Cut 5.1.4. But now, I want to export a still frame from one of my clips and it’s anamorphic! The image captured is 16:9 but the still frame shouldn’t have an anamorphic aspect.
    What can I do?
    Thank you for the help.
    Renata
    Jeremy Garchow replied 19 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    June 21, 2007 at 3:26 am
    Yes it should, all HD cameras record anamorphic to tape.
    Very few cameras record full raster.
    Jeremy
  • Michael Gissing
    June 21, 2007 at 3:52 am
    Renata,
    I suggest taking the shots you want to extract stills from and dropping it into a new sequence that is set to HDTV Uncompressed 10 bit 422 (50i or 60i depending on your source footage)
    You will see a render bar but I don’t think you need render anything as you are just extracting a still frame. As the sequence setting is for 1920 x 1080, you should be able to extract your still frame in the correct aspect ratio.
    Make sure in your export settings that the pixel aspect is 1920 x 1080.
  • Jeremy Garchow
    June 21, 2007 at 5:30 am
    I’d take the anamorphic still into photoshop and resize to 1920×1080 (instead of 1440×1080 or whatever it’s at now)
  • Renata
    June 25, 2007 at 2:32 am
    Hi Jeremy,
    I agree with you but do you know how I could export it not looking anamorphic?
    Thanks for your help.
  • Renata
    June 25, 2007 at 2:36 am
    Thanks everyone for your help but changing the sequence settings didn’t work either.
    I still didn’t find a way to export it right. The solution is to keep trying diferent ways.
  • Tom Wolsky
    June 25, 2007 at 3:13 am
    The solution is the one you got, to change it to square pixel aspect ratio in a graphics application like Photoshop. You didn’t say but I’m guessing you’re working in 1080. You need to make it 1920×1080 and remove the interlacing while you’re at t.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Jeremy Garchow
    June 25, 2007 at 2:16 pm
    Photoshop is the best way.
