Activity Forums Apple Final Cut Pro Legacy To deinterlace,or not to deinterlace
  • To deinterlace,or not to deinterlace
    Posted by Chad Mayeux on January 8, 2009 at 2:02 pm
    Every week at work I get handed a dvd of last Sunday’s services from a local church that I then rip, edit down to 60 minutes and schedule to play on a local access channel. First I rip the footage from the dvd, I copy the VOB video files and convert it to DV footage using MPEG streamclip and then import that resulting file into a FCP timeline. There I trim it down to 60 minutes and then export it to compressor and compress it using an MPEG-2 encoder. There is always the option within compressor or MPEG streamclip to deinterlace the footage. My question is, at what point would it be worth deinterlacing, if at all? Thanks in advance for any help!
    Chad Mayeux replied 17 years, 8 months ago 3 Members · 5 Replies
  • David Roth weiss
    January 8, 2009 at 2:13 pm
    It would be worth doing only of you wish to sacrifice 50% of the vertical resolution of your video.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Chad Mayeux
    January 8, 2009 at 2:16 pm
    So is deinterlacing SD footage ever worthwhile? Should I keep all interlaced footage as so or does it depend?
  • David Roth weiss
    January 8, 2009 at 3:00 pm
    [Chad Mayeux] “So is deinterlacing SD footage ever worthwhile?”
    Not if you’re broadcasting material that was shot interlaced.
    [Chad Mayeux] “Should I keep all interlaced footage as so or does it depend?”
    If you’re cutting interlaced clips into a project that is progressive, then deinterlace. If you’re compressing interlaced material for the web it can make sense in some, but not all situations. For example, if your Web video is going be 50% smaller than your original video size, deinterlacing should not be necessary.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Ed Dooley
    January 8, 2009 at 3:01 pm
    Not necessarily true. Yes you’ll lose the resolution if you use the simple de-interlace filter in FCP (and many other programs). If, however, you use Frame Controls in Compressor (do a search of this forum and you’ll find lots of instructions), you do not lose res, the fields get blended. There are 3rd party products that do the same thing (Nattress has one).
    Having said all that, I wouldn’t deinterlace unless you need to (like for the web for example), the program’s going out to TV? Leave it interlaced.
    Ed
    [David Roth Weiss] “It would be worth doing only of you wish to sacrifice 50% of the vertical resolution of your video.”
  • Chad Mayeux
    January 8, 2009 at 3:06 pm
    Ok, that is much more clear! Thank you David and Ed for your help! Slowly but surely I am getting a handle on some of the technical aspects of this industry. I have a lot to learn still! Again Thanks!
