Activity Forums Adobe After Effects to continuously rasterize or not to continuously rasterize
  • to continuously rasterize or not to continuously rasterize
    Posted by Heather Crank on October 2, 2008 at 1:52 am
    Hello!
    I have several layers of a logo that I pre-comped so I could apply a bulge effect to the logo as one element (instead of a bunch of layers). When I turn ON the continuously rasterize button the type is crystal clear but the bulge effect and the shadow from a light I have shining on the logo disappear. When I turn OFF the continuously rasterize button the type looks fuzzy and the shadow returns. Anyone know how this can be fixed?????
    Heather
    Heather Crank replied 17 years, 7 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    October 2, 2008 at 3:53 am
    Apply the bulge to an Adjustment Layer in the precomp. OR Set the scale of the precomp layers large so that you don’t have to use Continuously Rasterize in the ‘final comp’. I am assuming that you’ve got CR turned on because you are enlarging the nested composition in the ‘final comp’.
    Cheers
    RoRk
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Heather Crank
    October 2, 2008 at 4:04 am
    THANKS RORK! THAT SHOULD WORK I’LL TRY IT NOW.
    YES I’M ENLARGING THE NESTED COMP IN THE FINAL COMP.
    THANK YOU SOOOO MUCH!
    H
