Activity Forums DaVinci Resolve To Charlie and Warren : Davinci panel combination keys?
  • To Charlie and Warren : Davinci panel combination keys?
    Posted by Gabriele Turchi on February 20, 2011 at 11:18 am
    Hi warren/Charlie
    I took the old FxPhd course and i do know that you 2 guys guys Resolve as no others …
    I have the Resolve Panel and i can’ get any documents about buttons combinations …
    for example you guys in one of the class used the combination :
    -,+ ripple value to apply the grade to the all timeline …
    how many others combination exist ?
    would you be so kind to write a little list here ? (seems that nobody else know this…)
    g
    David Catt replied 15 years, 6 months ago 3 Members · 3 Replies
  • Emilio Batungbacal
    February 21, 2011 at 4:38 am
    Not Charlie or Warren but here are a couple more shortcuts.
    +x ‘Preview Mem’ or -x ‘Preview Mem’ to copy grade. x is a number relative from your current scene. e.g. +2 ‘Preview Mem’ copies the grade 2 scenes after your current scene.
    Will also work with ‘Play Still’. Most of these are 2K plus shortcuts.
    Emilio Batungbacal
    Colorist
    ZAP! Visual Effects
    https://colorist.batungbacal.com
  • Gabriele Turchi
    February 21, 2011 at 5:07 pm
    Thanks Emilio!
    But i guess that the scroll mode on Resolve (only supported on the Resolve Panel I guess) it does the same thing …but in a easier way …
    g
  • David Catt
    February 23, 2011 at 2:07 pm
    Those fortunate to use the Resolve control surface can use the “:” and the “,” that is the “colon” key and the “comma” key. These can be found on the right hand side of the numeric key pad and provide a “-2 Preview” or “-1 Preview” respectively.
    David Catt
    ColorScene
