Activity › Forums › Adobe Premiere Pro › To Aanarav
  • To Aanarav
    Posted by Hector Melendez on February 26, 2006 at 4:16 am
    Thanks a million for your efforts about the “multicam ” article. Good job!
    Now only have a small question, where in the process of creating the secuences is that we sync the raw footage so when we switch from TL all is “sync”
    Thanks again
    Aanarav Sareen replied 20 years, 7 months ago 2 Members · 3 Replies
  • Aanarav Sareen
    February 26, 2006 at 4:51 am
    That tutorial is coming soon. Stay tuned 🙂 It is a rather lengthy process and it requires seeing it visually. But, if you can wait for a while, it will be here….
    Aanarav
  • Hector Melendez
    February 26, 2006 at 5:22 am
    Ok, ok…In the meantime I found a way just by making a cut in one of the timelines at a specific spot, locking it & making it invisible; and finding the same spot in the other secuence and cut in the same spot, then I aline both cuts…. easy! (working with 2 cams shoots only)
    Well, will like to remember in your next article what to do or if it’s possible if I already did a multicam edit if I can add more footage to the same process already done.
    I’m working in chunks of 5-6 mins but find now that I can’t get multicam enable again in the same multicam secuence….Comprendes amigo?
    How I can continue adding more footage to edit or I will have to start over to complete the next footage????…..
    Thanks amigo
  • Aanarav Sareen
    February 27, 2006 at 3:29 pm
    [Hector] “.Comprendes amigo?”
    Not really. Can you please explan the steps in detail?
