Activity › Forums › Apple Final Cut Pro Legacy › TO 24 or not too
  • TO 24 or not too
    Posted by Thew on July 21, 2005 at 5:36 pm
    Hi all,
    Just wondering if I should capture in 24p under my capture presets..
    I have been shooting with the dvx100 in 24p, and just capturing in 29.
    However, was wondering if this is something I should look into..
    My final output is broadcast..
    Do you think I will make my footage look better?
    Any thoughts
    Graeme Nattress replied 21 years, 2 months ago 3 Members · 2 Replies
  • Shane Ross
    July 21, 2005 at 6:52 pm
    Capture 24P as is 23.98 fps? Then no. If your final will be output to tape, then capture at 29.97.
  • Graeme Nattress
    July 21, 2005 at 8:41 pm
    https://www.kenstone.net/fcp_homepage/24p_in_FCP_nattress.html explains all.
    NTSC DV is always 29.97fps no matter what! If you tell FCP to capture at 23.98fps, it will, but because the tape is not at that speed, it will just randomly drop frames.
    If you shot in 24p Advance, capture as 29.97 with the advanced pulldown removal function, and FCP will remove the correctly falgged frames to give you true 24p.
    If you shot in 24p 3:2 pulldown, then just capture as normal NTSC.
    Don’t whatever you do set FCP to capture with a 24p timebase or it will mangle your footage.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
