Activity Forums DVD Authoring TMPGENC DVD Author 4 – menu issue
  • TMPGENC DVD Author 4 – menu issue
    Posted by Luke Ho on January 6, 2010 at 6:57 pm
    I’m trying out TMPGENC DVD Author 4 software for the first time. It does seem to be straight forward from the point of importing the source files (VOBs) to creating the menu and authoring the DVD. However, the generated DVD (still in ISO and played with a computer dvd player), I can’t seem to go to the DVD menu. When I click on the DVD root menu, I can see the menu for a second, then it pops right into the beginning of the DVD and start rolling. It appeared fine in the test simulation.
    Under “Menu structure setting”, I’m currently selecting “Track menu only”, then under “Menu action setting”, I have
    . Disc insertion action: Display the track 1 track menu
    . Track playback end action: Play the next track
    I also tried the above menu structure setting as “Automatic” with the same result.
    Where can I look into fixing this?
    Thanks very much in advance.
    Luke
    Luke Ho replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
