Activity Forums Avid Media Composer Tme Code Breaks, Capture Stops
  • Tme Code Breaks, Capture Stops
    Posted by Deepmine on August 6, 2005 at 10:39 pm
    My shop is going to Avid NewsCutter, and I’ve been playing with it for about a week now.
    During our basic training session with an Avid staffer last week, a fella across the romm was having trouble with capture.. I wasn’t having any problem, so didn’t pay any atttention. but it had somethign to do with drop frame tc slaoved by renaming the tape and trying again.
    On a couple of occassions this week, while trying to grab a long interview off DVCPRO, I had the capture stop in the middle and got a message to the effect that there was a break in the time code… looking at the tape on the deck revealed no breaks.
    Any info would be appreciated… the only thing I can find on-line are references to improper use of the camera in terms of powering up and powering down.
    Thanks, J.S.
    Don Logan replied 21 years ago 3 Members · 2 Replies
  • Satesh Ramjattan
    August 6, 2005 at 11:31 pm
    in the capture tool, try turning off the “toggle source” button, its the button that looks like a deck.
  • Don Logan
    August 12, 2005 at 11:00 pm
    Go to capture setting in your project window under settings tab. make sure “capture across timecode breaks” is turned on
    The globe icon/toggle source deck thingy icon is o.k if you dont need time code or you can just unselect timecode without toggling source.
    rd
