Activity Forums Apple Final Cut Pro TKY Power Grade Lite
  • TKY Power Grade Lite
    Posted by Simon Ubsdell on November 18, 2011 at 8:32 pm
    A simplified, but also enhanced version of the Power Grade Effect which removes the highlights/shadows and diffuse components which experience showed could have an adverse affect on render times, but at the same time adds in the ability to grade both inside and outside the “power window”.
    3287_tkypowergradelitev2.zip
    There are controls for:
    – Master hue, white and black level, saturation, brightness, gamma, contrast and contrast pivot, shadows/midtones/highlights color balance;
    – Master tint, tint intensity, and tint on/off, sharpen and sharpen intensity;
    – Power Window On/Off, show window mask (as grayscale image), window shape selector (circle/rectangle);
    – Window scale, aspect ratio, shear and feather;
    – Inside window hue, saturation, brightness, gamma, shadows/midtones/highlights color balance;
    – Inside window blur;
    – Outside window hue, saturation, brightness, gamma, shadows/midtones/highlights color balance;
    – Outside window blur;
    – Broadcast safe region selector (PAL/NTSC) and fix method (none, luma, chroma or both)
    There are onscreen controls for the window position, rotation and scale, while an additional control at the bottom left hand corner affects the window aspect ratio. This works in such a way that dragging the control upwards increases the vertical scale, dragging it to the right increases the horizontal scale, and dragging it all the way into the left hand corner will reduce the window to nothing.
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
    Simon Ubsdell replied 14 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
