Activity › Forums › Apple Final Cut Pro › TKY Free FCPX Reflection Effect
Simon Ubsdell replied 11 years, 10 months ago 6 Members · 17 Replies
Joe Lombardo
December 22, 2011 at 4:23 pmI’ll give that a try too.
Basically I’m looking for a transition, like Swap, that I can hold midway through to get a side by side (or pseudo PIP) for a period of time. Then reverse the transition to bring the main video back to full screen.
Apple uses something like this during their keynote events.
Keyframing this in and out transition dozens of times through a two hour video is extremely time consuming so I’m hoping there is an easier way.
Simon Ubsdell
December 22, 2011 at 6:05 pmIf you wanted to give me some more precise co-ordinates/timings for this then I’d be happy to adjust the template to make it work that wya for you … as I say, it’s easy to do and would be an instant answer to your keyframing headaches.
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com -
Simon Ubsdell
December 22, 2011 at 7:51 pmBecause it’s Xmas I thought I’d make this for you anyway – it’s an effect that enables you to bring on a PiP, have it hold and then move it off without you having to keyframe anything:
For example, you can set the position from which the PiP starts (defaults to offscreen Right) using the Start X/Y Pos parameters, and the start scale using the Start Scale parameter. Similarly with the position and scale for moving the image out of screen (End X/Y Pos, End Scale).
You can set the hold position either using the onscreen control or in the info tab, and you can also set the hold rotation value, as well as the initial (and end) rotation values).
The speed of the animation in and out can be controlled using the Speed In/Out parameters.
Again no keyframing is required at any point which should massively speed up your workflow.
In order to get the full Apple effect that you’re hoping for you could use it on both images but on the one that needs to come and go from full screen you just have to set the parameters to the reverse of the defaults, so that the start (or end) X/Y Pos are at zero and the scale at 100%.
Hope that all makes sense!
Simon Ubsdell
Joe Lombardo
January 9, 2012 at 6:40 pmI just got back from holiday break and found this one last present that Santa Simon left under the tree!
Thanks so much – I will be trying this out today!!!
Simon Ubsdell
January 9, 2012 at 7:53 pmHahaha (or should that be ho ho ho!?) – hope you find it useful.
Simon Ubsdell
Mike Rivera
October 22, 2014 at 7:32 pmHi Simon,
I am looking for this exact same effect for keynote presentations. Do you still have it?
Simon Ubsdell
October 22, 2014 at 9:12 pm[Mike Rivera] “I am looking for this exact same effect for keynote presentations. Do you still have it?”
Check out my extremely popular free picture-in-picture effect available from FxFactory: https://tokyo-uk.com/fcpxeffects/pipfree.html
Reflections and a lot more.
Simon Ubsdell
tokyo-uk.com
