Activity Forums Adobe After Effects TIVO Effect
  • TIVO Effect
    Posted by Reanimator1 on December 2, 2005 at 9:05 pm
    Hello,
    I am trying to duplicate the effect of a program being paused and then rewound using a TIVO or other DVR device using after effects 6.5. I want the reverse motion to be jumpy like it is when rewinding using one of these, (dropping frames). If anyone knows a quick way to do this, (i.e. not by hand), I would very much appreciate the info.
    Sean
    Mark Landsburger replied 20 years, 9 months ago 3 Members · 2 Replies
  • Chris Smith
    December 2, 2005 at 10:13 pm
    My guess it to speed up the layer a lot say 400- 800 %. Pre-comp this. On the pre-comp add the effect>Time>’Posterize Time’ effect and set it to only show you a frame a couple of times a second.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Mark Landsburger
    December 3, 2005 at 3:30 am
    Don’t know if it’s available to you, but this would be MUCH easier to do in Premier (for me anyway).
    Layer starts
    Cut where you want to pause / frame hold on in point
    Make this track as long as you want the pause
    Cut past paused track right after it
    Reverse speed
    Past track again and play as normal
    You could then add “lines and static” as needed in AE
