Activity Forums VEGAS Pro Titling tip: Inkscape!
  • Titling tip: Inkscape!
    Posted by Arthur Bueno on January 7, 2007 at 6:56 pm
    I want to share a solution I recently found for a long-time frustration with Vegas Titling capabilities. I’m not talking about 3D-things or FX, but simply the situation when you have made 20 or more titles, decide that you want a different font or color or allignment or whatever, and then have to go through all the clips and change the settings manually for every title, one by one.
    This time I made one large document in Inkscape (a great freeware open source vector drawing program, (https://inkscape.org/), in which I create all the titles. It gives me a quick overview of all the titles, and the ability to change styles/backgrounds/fonts/kerning/ etc. for all the titles at once.
    Export has to be done per title but goes fast, because inkscape remembers the filename once you’ve exported a group of objects for the first time.
    If you’re interrested how I do it, you find an example .svg file at
    https://www.mediamax.com/Arthur23/FileManager#
    Btw, I also use the inkscape documents to note any creative ideas, notes, any picture material that that comes up and I want to have access to. Apart from being a title repository it serves as a wonderfull scrapbook for my projects. Also great for storyboard, schematic sketches, thinkpad. Because it lets you zoom in and out endlessly you it helps you to structure complex projects.
    Arthur Bueno replied 19 years, 8 months ago 1 Member · 1 Reply
