Activity Forums Adobe Premiere Pro titling
  • Posted by Joep88 on November 22, 2005 at 2:49 pm
    Is there any way to get the screen of the title tool bigger than it is ? i stretched it but i is still a bit small. difficult editing of the titles.
    http://www.multimediasolutions.nl
    ASUS P4C800 de luxe
    Matrox Parhelia 225
    BMD Decklink Pro
    2 gig internal memory
    2x 120 gig HD
    Multible Firewire Disks
    Adobe Premiere Pro
    Combustion 3.0
    Photoshop
    Adobe Audition
    Cubase SE
    S
    Jim Arcon replied 20 years, 10 months ago 4 Members · 4 Replies
  • Steven L. gotz
    November 22, 2005 at 3:39 pm
    Stretched to where the titler takes up the entire screen, it is as big as you are going to get it.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Marc Brak
    November 22, 2005 at 4:09 pm
    I agree though, it still can be difficult to see everything clearly e.g. when working with small fonts.
    One should be able to zoom in, within the titler.
    Also, a grid option would be extremely handy.
  • Joep88
    November 22, 2005 at 4:18 pm
    Yes, if Adobe sells it as Pro, it should be Pro.
    ASUS P4C800 de luxe
    Matrox Parhelia 225
    BMD Decklink Pro
    2x 120 gig HD
    Adobe Premiere Pro
    Combustion 3.0
    Photoshop
    Adobe Audition
    Cubase SE
    S
  • Jim Arcon
    November 23, 2005 at 2:16 am
    Most of us would agree that the titler needs to be able to magnify larger and maybe have a grid. I solved the alignment problem with a grid (scanned, I think) that I import into the project as a jpeg. Drag it to the timeline, layout the title over it, then clear it from the timeline.
    If you want to really get fancy, you can even make it partly transparent, then put it above the layer you are titling.
    Yeah, not a great substitute for the real thing, but Premiere’s current titler is a LOT better than it used to be.
