Activity Forums Apple Final Cut Pro Legacy Titles/Credits DV Looking bad
  • Titles/Credits DV Looking bad
    Posted by Paul Stroud on January 29, 2011 at 5:38 pm
    Hello people,
    Some of the titles at the beginning of this music video I’m working on look great through a dv render as a slight TV/Film 70’s style burnt-in white text look is desired. You know, it’s got a slight glow to it
    I have digitized super8 footage on dv pal and have been editing in this format – looking great. The end credits however and some of the other smaller text bits are a little fuzzy
    What can I do?
    Shall I render in another format and put the credits on THAT?
    Any thoughts?
    Paul Stroud replied 15 years, 7 months ago 3 Members · 18 Replies
  • 18 Replies
  • Chris Tompkins
    January 29, 2011 at 6:09 pm
    Once the edit is locked. Change the sequence codec to DV50 and re-render all. This will yield much better results. Also could use 8-bit UC but probably overkill.
    Chris Tompkins
    Video Atlanta LLC
  • Paul Stroud
    January 30, 2011 at 4:00 pm
    Thanks Chris,
    Something’s not right – it doesn’t seem to be having any effect. Text is still a bit ‘Liney’ and unclear. Even using a motion project to generate text is giving me the same results
    And as for 8bit UC. Well, excuse my ignorance but I don’t know what that means and I can’t seem to find any setting pertaining to it either
    Cheers
    http://www.paulstroudmusic.co.uk
    http://www.stroudandcroft.co.uk
    myspace/paulstroudmusic
  • Paul Stroud
    January 30, 2011 at 4:01 pm
    Oh – and the movement isn’t very smooth. Any thoughts on that?
  • Chris Tompkins
    January 30, 2011 at 8:44 pm
    Will need sequence settings please.
    8bit UC Uncompressed.
    Chris Tompkins
    Video Atlanta LLC
  • Paul Stroud
    January 31, 2011 at 2:46 pm
    Oh – ok uncompressed
    These are the setting I used with the edit.
    If I set the field dominance to ‘none’ it looks great, but the denoiser I used seems to need this set to ‘lower’ to run – in fact a setting of none causes FCP to crash because of the denoiser. Unless I’m doing something wrong here? Which is very possible 🙂
  • Chris Tompkins
    January 31, 2011 at 4:32 pm
    Is the footage progressive?
    Render settings set to FULL & BEST everywhere?
    That denoiser may only be so good?
    Chris Tompkins
    Video Atlanta LLC
  • Rafael Amador
    January 31, 2011 at 4:50 pm
    [Paul Stroud] “but the denoiser I used seems to need this set to ‘lower’ to run – in fact a setting of none causes FCP to crash because of the denoiser.”
    I guess you are talking about the “de-interlacer” instead of “de-noiser”, don’t you?
    rafael
    http://www.nagavideo.com
  • Paul Stroud
    January 31, 2011 at 4:55 pm
    It’s Super8 footage that’s been transfered to dv tape PAL. So I guess no – it’s interlaced
    It’s the Magic Bullet denoiser and has helped a lot with the interior footage.
    I suspect that the denoiser is not happy when I tell it that the sequence has no field dominance if the footage is actually interlaced.
    I wish it had been transferred progressive. Would it be worth de-interlacing?
  • Chris Tompkins
    January 31, 2011 at 5:13 pm
    What did they dub the 8mm film to? What format?
    Chris Tompkins
    Video Atlanta LLC
  • Paul Stroud
    January 31, 2011 at 5:23 pm
    I spoke to the telecine op and I think he said that it first went to digibeta before being transferred to dv tape PAL
    I hope that’s what you wanted to know. It’s all a bit new to me so forgive the ‘Holes’
