Activity Forums Adobe Premiere Pro Titles that can’t be seen
  • Titles that can’t be seen
    Posted by Eric Merklein on May 19, 2019 at 5:43 pm
    I’m in a 1080 project using material that was shot 4K.
    PROBLEM: I created two lower thirds for on camera ID’s. When I put the title over video in ch. 1, I cannot see the title. If I double click to get into the title tool, I can see it.
    Rendering doesn’t help and i cant see the lower thirds even if I insert on ch 1.
    I hope someone has a fix for me.
    Many thanks.
    Eric
    Eric Merklein replied 7 years, 3 months ago 2 Members · 4 Replies
  • Paul Neumann
    May 20, 2019 at 3:29 am
    Right click on the title and set to frame size.
  • Eric Merklein
    May 20, 2019 at 10:37 am
    Thank you Paul. In all this time I haven’t seen this re-size option. It worked.
    Eric 🙂
  • Paul Neumann
    May 21, 2019 at 1:19 pm
    You’ve probably got a 4k title on a HD timeline. I bet if you check the scale on the title it will be 50%.
  • Eric Merklein
    May 21, 2019 at 1:25 pm
    You are absolutely correct Paul. Thank you for bailing me out
    e
