Activity Forums Adobe After Effects Titles not visible…
  • Titles not visible…
    Posted by Jerry Cast on June 3, 2009 at 8:38 pm
    Sorry for this basic question, but I’ve created an animated text in the color Yellow in AE CS3.
    Since I can’t see all of the characters when the text is superimposed on the video, I want to make a small oval background that’s semi-transparent that I can color and opacity adjust to make the text stand out but still see the underlying video.
    Thanks.
    Jerry
    Jerry Cast replied 17 years, 3 months ago 3 Members · 6 Replies
  • Jerry Cast
    June 3, 2009 at 10:18 pm
    Thanks Dave,
    I used the Rectangle tool in AE CS3, made it red (the text is yellow), and then down below choose Opacity to make the red almost see thru.
    The problem now is that the yellow text dulls down with the turning down of the opacity on the red, so now the bright yellow text is dull.
    Can’t figure out how to keep the yellow bright yellow.
    Thanks.
    Jerry
    https://www.jerrycastaldo.com
  • Jeremy Allen
    June 3, 2009 at 11:28 pm
    You may have already done this but if not, the most standard way to make text stand out against video is to use a bit of drop shadow.
    Also, changing the opacity of the red solid should not affect the yellow text. Sounds like something is screwy, unless you have the text set to a particular overlay mode i.e multiply, screen, overlay, etc..
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6
    AE CS3
    FCP 6.0.1
  • Jerry Cast
    June 3, 2009 at 11:32 pm
    Thanks Jeremy,
    I think (because I’m so new to AE) I have the text layer below the solid in that window on the bottom. Just thought of it and will try it later when I can.
    I’ll look for the drop shadow button in the text creation menu’s too.
    Jerry
  • Jeremy Allen
    June 3, 2009 at 11:35 pm
    No problem.. you can access the drop shadow thru the text layer’s layer styles or under effects>perspective>drop shadow. Or you can also type “drop shadow” in the effects palette search box.
    AE CS3
    FCP 6.0.1
  • Todd Kopriva
    June 4, 2009 at 3:43 am
    You can also use a drop shadow layer style, which is sometimes better than ye olde schoole way of using the Drop Shadow effect.
    A glow or stroke can also help the text to stand out against a background that has a color similar to the text’s fill color.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Jerry Cast
    June 4, 2009 at 1:43 pm
    Wow, thanks everyone. I was having a bit of trouble finding things in AE, but this is great.
    The only other thing is that I was able to successfully make a solid, size it to a rectangle, set it’s opacity, and get the text on top of it fine.
    But, I still can’t find the menu item that allows you to automatically draw ovals, circles, squares…
    I had it up on the top center left for a minute, then lost it and couldn’t get it back. The manual isn’t helping.
    Also, I’m trying to make a title (one line of two words) sort of slowly “quiver” or just move somehow (rolling like smoke) or just wave like a slow rolling ocean wave, but am having trouble figuring this out too.
    I noticed that Premier Pro CS3 has templates for lower thirds, but it looks like there are none in AE, right? One last thing, the solid seems to start “before” my “Animate In” text flys in from the side. I fixed it a little bit by trimming the start on the Dymanically linked AE title, on the Premier Pro timeline. But, it still appears fully a bit before the text. I was wondering if I can make that solid slide in “with” the text simultaneously.
    Sorry for all the questions jumbled into one post. But it exciting learning how to do this from you guys (and girls).
    Thanks again.
    Jerry
