Activity › Forums › Adobe Premiere Pro › Titles look bad in Premere CS5?
  • Titles look bad in Premere CS5?
    Posted by Rich Kaelin on October 2, 2011 at 8:53 pm
    I used to work a lot in Premiere, moved to FCP, now back somewhat in Premiere CS5. I am using Premiere because of titler, but the titles look great in titler window, then look like crap in project. They are jaggy, like no anit-alising on edges, really bad. Any thoughts, or is this “normal”? In ppro2 they looked fine.
    Rich Kaelin
    Kaelin Motion Production Services
    https://kaelinmotion.com
    New York
    Rich Kaelin replied 14 years, 11 months ago 4 Members · 6 Replies
  • Petros Kolyvas
    October 2, 2011 at 10:38 pm
    Is it possible your playback setting are half-resolution? (You can right click on the playback/destination window and select the playback quality.)
    One way to tell is if you hold/pause on a title (and the window returns to full-res) the title becomes “right” again.
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Rich Kaelin
    October 3, 2011 at 1:24 am
    I will check tomorrow when I go back to studio, but titles always look bad. They look fine in titler window, but bad in pgm window and in exported videos. I wonder if all project has a problem and it just pops on titles, but I don’t think so. Video seems fine, just titles keyed over look jaggy, not smooth edges. Never had this problem in older versions, so I am confused. Have had cs5 a while, but have not realy used it. Also, if I create title in after effects and nest it in premiere (ala motion in fcp) that looks fine. Only titler titles look bad. One reason I took this project to premiere was to make simple titles (I hate fcp options, all basically too slow work flow) and because premiere is easier to work with crappy video type client gave me, I don’t have to convert everything to work with it.
    Rich Kaelin
    New York
  • Jeff Pulera
    October 3, 2011 at 4:07 pm
    Hi Rich,
    What is the workflow – source format, export format?
    If for instance you’re exporting for the web/computer viewing, but the signal is interlaced, this would mess things up. Please share more info
    Jeff Pulera
    Safe Harbor Computers
  • Rich Kaelin
    October 3, 2011 at 6:03 pm
    I am editing in DV 16:9 mode and exporting via media encoder to .mp4 for youtube posting. My final output is progressive (matches their footage) at 854×480 square pixels. It is titler. If I do titles in AE they render fine. I am only using DV setting because client sent me lousy footage, but it is HD. Smaller size lets me resize and crop their footage for proper framing of shots. Video looks fine, AE titles Look fine, PS titles look fine, only titler titles have an issue. I seem to have very limited project formats in Premiere, the only SD 16:9 project seems to be DV.
    Rich Kaelin
    New York
  • George Uibel
    October 4, 2011 at 10:00 pm
    Also experiencing “sub-optimal” titling issues in Premiere Pro…Looks like’s it stuttering while trying to roll. Have tried adjusting times to address interpolation/math crunch issue, but without success. Boris titler in FCP seemed to create smoother, cleaner rolls. Any suggestions? Seems Boris makes a plug in for Premier, albeit pricy…
  • Rich Kaelin
    October 4, 2011 at 11:35 pm
    I do all my credit rolls in After Effects or even Motion. Very flexible. I like to do rolls where the space in middle stays the same and left column is right justified/right column is left justified, more film look, plus you can do other interesting things in the midst of the roll, so that is always my route.
    My issue is with simple still titles. I wanted the speed I remember from titler, but all the titles look like crap, i just cant figure it out. In previous versions I NEVER had this issue. I just feel like there is a setting I am missing. I generally don’t like Boris products. I just never get the interfaces.
    Rich Kaelin
    New York
